Saves the running configuration as a script.
| script-name | Specifies the name of the file to save the configuration to. The script file is known as the XOS script file and uses the .xsf file extension. |
N/A.
This command allows you to save the current configuration as a script and export it out of the box for later use.
The script is saved on all the nodes in a SummitStack when the save configuration as-script command is executed.
The following example saves a running ASCII-formatted configuration named primary.xsf.
save configuration as-script primary.xsf
